Mweb/frogfoot 1Gbps Uncapped Fibre?
Sneeky
Durban
Sorry if I missed other feedback but could not find anything specific.
Moving off LTE that has just pretty much died here in AmanzimTexas and since fibre is around of late, time to move.
Any advice on routers, as I see they have an optional choice, to go with their supplied one, or something else the user may provide?Zyxel EMG3525
Thx
Thx
If you’re going to spend good money monthly on a Gbps service, spend good money on some network hardware. Get a decent router, switch and some access points, or a good mesh if your budget is smaller. Anything less and you’re throwing good money at a bad network.
Thank you, precisely the reason why I asked as I don't know what to look for, been on LTE for years.
Any advice or recommendations on router are most welcome.
I don't believe I need anything other than a router, and some wireless capability for tv's and devices around the home. My LTE router covers this at the moment, just the service has degraded overtime.
I'm ignorant on fibre gadgets so yeah, if there is a preferred option for gear other than what is provided by the ISP, I will certainly get it.
Thanks again.
Are you sure you need 1gbps? Perhaps 100mbps would be more suited to your needs
This ^^
Most people who have connections faster than 50Mbps probably waste money unless they specifically get it to save time on waiting for downloads.
If you only stream and browse then there's no noticeable difference between 50Mbps and 10Gbps even - unless you have a huge house with multiple 4k streams etc.
Thanks again.
Let’s start backwards. A ‘good’ router can set you back anything from R600-R <insert your lottery numbers here>. It depends on what you need. Obviously this is for your home, so you can cap your needs, so we’ll get to this once you’ve got your budget on the access portion sorted.
Let’s look at access first. This is where your budget needs to go. First- decide if you can run LAN cables throughout your house to make sure you get 1Gbps to every corner or not. If not, skip this next section.
It’s highly unlikely your solution will give you 1 Gbps on every wireless device. So set your mind on a more reasonable 300-500 for each wireless device- unless you want to spend big bucks on APs.. Consistent and pervasive coverage is more important for me than being able to blast 1Gbps in one spot, but being unable to watch Netflix in bed. Ubiquity’s UniFi range of APs are great- the new AC lite WiFi 6 devices are awesome. Consistent connectivity and good coverage at a reasonable price. TP link have their Omada range which are quite a bit cheaper and there are also new entrants like Reyee who have great APs at 1/3rd the price of a UniFi. Remember the APs above will all need you to run some CAT6 cables to them).
Also try running lan cables to your PC, consoles and tvs.
Next is considering a good switch. POE is nice to power these APs remotely. To be honest, you don’t need fancy management functionality in your home - so a simple 8/16 port Gigabit POE switch will do.
Finally, for your router. If you’re going ubiquity and your budget allows, look at their USG options. It ties up nicely with their solution and they’re all more than capable of doing 1Gbps (although the smaller ones will lose DPI and threat management functionality if you want 1G speeds). Your router’s job is to establish the wan connection, provide firewall and manage your LAN network (DHCP, DNS, port forwarding etc). Your ISP’s supplied router should be able to get these right (albeit poorly) - so you can simply disable WiFi on this box and use it as a starter router. If you’re feeling confident about your network skills, you can look at a MikroTik router- but be warned, these take some skill.
If you can’t run cables- invest in a decent Mesh solution. These range from units that have built in routers to ones that are just APs. Make sure you pick well. There are good solutions from Tenda and TP link and airties.
This ^^
Hi, almost most certainly don't need it, just nice to have, however, I spend on average R2k a month on LTE, mine is not uncapped.
Going for the Mweb solution reduces that cost by a third to almost half if I go with a slightly slower connection, increases speeds and offers uncapped. So while excessive, I am still saving.
I'm am more than happy to pay up for service that is fast and reliable when I need it, rather than struggle. My LTE the last while reduced to 5mbps at best, last 2 weeks 1mbps. Tired of struggling.
Thanks @cantankerous for your advice. Much appreciated.
Essentially my current LTE router has lan cables already to 2 tv's and pc, I expect I just need a fibre router to replace the lte one?
Laptop/Tablet/phones link wirelessly currently.
I'm confused as to the switch inclusion, unless the routers don't have multiple lan ports or lack wifi. Excuse my ignorance.
I'm not a heavy user, just want a fast reliable connection.
Will have a look at the hardware you have mentioned and digest.
Thx
