S Sabstance New Member Joined Dec 7, 2024 Messages 2 Reaction score 0 Dec 7, 2024 #1 I am trying to load a token on a Conlog meterbox. Zero does not work on the meterbox now I am without electricity.
epah Honorary Master Joined Apr 22, 2014 Messages 24,322 Reaction score 27,102 Location MYBB HoofKantoor! Dec 7, 2024 #2 How have you been loading tokens all this time?
leon.davibe Executive Member Joined Feb 3, 2009 Messages 5,194 Reaction score 2,215 Dec 7, 2024 #3 Most likely dirt is causing the button to not make contact or the carbon stub or whatever it was is worn off not conducting Can also try using a pen or pencil to apply more pressure Yea had a media centre remote that would start behaving like that with age And the replacement eventually did the same
S Sabstance New Member Joined Dec 7, 2024 Messages 2 Reaction score 0 Dec 8, 2024 #4 epah said: How have you been loading tokens all this time? Click to expand... I last loaded on November 23
U upup Executive Member Joined Jun 1, 2009 Messages 9,996 Reaction score 1,734 Location currently offline Dec 8, 2024 #5 you tube shows you how to repair them. My one remote, I even glued other remote carbon on it. Who does the conlog belong to, you or the munic.
