My DSTV is acting up
Slaught3r
Favela
Hi,
Hopefully someone here can give some advice?
I have a HD PVR and Dual view. For some reason when I go to Box Office it gives me E02 - No box office titles found. Also, when I go to catch-up (or whatever its called now) there are only one or two shows. Not sure what could be causing this but it is quite frustrating. I don't PVR a lot of shows because I can always get them on catchup, but now the problem is they are not there...
Any advice? Not sure what to do.
4 tuner or 2 tuner?
If 2 tuner, can you record & get the TV Guide? If not check connection to tuner 2
If 4 tuner, can you get the TV guide? If not check connection to tuner 4
It is a 2 tuner - I have checked connections and everything looks in order. I did the installation myself, so maybe I should rather get a guy out to come have a look to make sure I didn't c0ck up anywhere. Any good/reliable installers out in the East Rand?
