Went on to my ipas (3 yrs old) this morning and it cannot connect to my wifi router. I rebooted my router and rset it on the ipad but no luck. My Kindle can log on to Amazon so it's not a WiFi problem. Can anyone help me either on this formu or PM me. Thanks.
If the reset does not work (it usually does) power it right down and back again. On an Android phone you can get a free app that tells you the signal strength of the wi-fi
If you find one for the iPad that works, let me know. iPads (3 and below) do not seem to have good wifi performance
Thanks all. I went to my local istore and it worked just fine. The guy there said to delete my current connection and remake to my router. All fine now thank goodness as I cant afford a new one.
