mybb site, strange issue on ms edge
skimread
Zumbabwe
I have this strange issue on ms edge (developer edition) with mybb. No other site.
On MS edge the paging element is not showing but on Chrome it is.
If I take a screenshot on edge you can see it's missing
Anyone else experiencing it on Edge?
Both chrome and edge are using chromium so it doesn't make sense the page would render differently.
If I remove the div's css class tag or remove the class' float property is becomes visible.
Code:
block-outer-main {
float: left;
which is weird
Code:
block-outer-main {
float: left;
which is weird
I use the dark theme and MS EDGE and it looks fine.
What version are you running? (edge://version/ in your address bar)
I am on Version 85.0.538.0 (Official build) dev (64-bit)
Well, if you are running bleeding edge software, you are likely to find bleeding edge issues..
