Dare
Hi guyz
I need some help from you programming guyz.
Ok here's my situation:
I have a number of websites that use the same website script, the script uses a mysql database.
What I would like to do is create another website that has all the data of these sites. It will use the same script.
So i need some how to amend all the MySQL data into the one MySQL DB.
I have found a script that exports all your mysql data into a file then uplaod with FTP to location of ur choice.
So now that I have these files how do I amend those .sql files into the single DB?
thanks very much for help!!
