N95 WLAN Signal?
I am no expert but does the N95 not just pick up available signals? So if the signal you are trying to pick up is not strong enough then it is the transmitter that needs to be boosted not the N95....
I may be totally wrong however....
THe signal on the phone is pretty bad, its mot meant to be strong. The only intention was to use it in a hotspot environment which has clear strong signal.
There is not alot you can do to boost it.
What you can do is to increase the signal strength on your AP by using a strong omni or possibly a directional but that probably wont work either.
Move closer to the AP?
Increasing wireless signal
You have to upgrade the phone's firmware to version 20. That greatly enhances the wireless signal. If you have a vodafone branded n95 you will first have to change the phone's product code with nemesis and then do the upgrade using Nokia Software Updater.
