Need a air purifier
So i guess this should be a good deal?hepa filter and all.
http://dischem.co.za/product-view/49400/vicks-hepa-air-purifier
Just check the volume of air it processes.
That thing looks like a bedside device that keeps the surrounding air clean.
You probably want a higher-volume filter that attempts to keep your whole place clean. That's probably where the high cost comes in: More volume. The smaller units are probably fine for your desk.
Reviews state people move it around the house
Whole room gets covered as i read it
I've found the 5-stage purifiers to be the best. I use RabbitAir in the US (I have 4 of them). I have family that have bought a SplendidAir in SA and are happy with it. http://splendidair.co.za
HEPA is one of the stages - whatever you choose make sure it has a HEPA in it.
The one stated above is HEPA and ionic enabled if you choose to enable it
Well it's only 2 hours but you get that clean smell to the air now
nose is not that itchy as well! Not the softest but hey works good so far
