Need a Pre-Chromium Edge Installer
UrBaN963
JHB
Anyone got the offline installer for the pre-chromium version of Edge?
This may be worth a try:
If not, then try Internet Explorer.
Problem is I don't have the old version of Edge installed, so this doesn't work, hence the need for the offline installer.
I have a specific issue I have to test on this version of Edge, no other browser will work for this unfortunately.
maybe spin up a vm with an old windows 10 or 8.1 ISO that still has OG Edge on it.
