Plasticmonkey
Hi guys.
Ive been having some trouble with my PC, and I think it is my Asus p5n-D motherboard that is causing the problem. (check my Sig to see my PC spec)
I have been using this system for about 6months now (no hardware changes since then), but this moring my PC decided to go crazy.
For some strange reason the PC refuses to go past the Bios startup screen.
I have tried everyting I can think off, including: Swapping ram/removing modules. Swapping hdd's. swapping gfx card, swapping keabords, clearing CMOS. I even replaced the CMOS battery.
Weird thing is I can only get to the Bios starup screen if I unplug the pc from the wall for about 30sec, plug it back in, and startup. on the rare occasions that I could get into the bios by pressing DEL (only once every 20 startups) it freezes in the bios, and I get a long continious beep from the speaker. If I try to startup again after that I get a blank screen.
So basically I cant even get into the BIOS to fiddle around with settings, although I doubt that is the problem, coz I have been using the PC with default BIOS for 6 months.
One or twice during my hunderds of startup attepts I did get the following msgs: "CMOS Checksum error, defualt bios loaded" or "BIOS ROM checksum error"
I googled the problems, and I have tried everything that came up, but I cannot seem fix this.
The mobo is loaded with the lastest firmware that I have been using for at least 2months without a problem.
Suggestions to a fix???
EDIT: I forgot to add: I removed The RAM, and tried to startup, and the Beeping error codes seem to work just fine. Whenever I dont get a bank screen on startup, I get the normal beep it always makes.
