Need a web dev recommendation
TheMacintosh
Hi all,
Our company currently needs a frontend web app to be built. It's going to have to be built in React & Next.js. Its probably a 2-3 month project for 1 dev. It's not a landing/marketing site, but a fully working UI that integrates to our backend.
I thought I'd check on here if there are any suggestions... is there any recommendations for dev houses, or developers that are currently freelancing?
Thank you :)
Hi. Is the front-end/backend stack up for discussion? Could you please give more info on the backend you'd be using?
Do you already have a speciations document or will you need assistance drawing it up?
I'm not available at the moment, but I'm nearing the end of a 3 month project for another member who posted a similar thread.
Backend already there with a working frontend. We need to redevelop frontend in a more modern framework for many reasons not worth going into here. I normally do the development but I don't have the time, plate is full - hence I'm shopping it out. Frontend stack not really up for discussion at this stage.
