Need ADSL - Help
RVR
Durban
Hi
I want to get ADSL Uncapped , the price always causes a problem however i have not done any research to see what are the current deals etc.
I need something that is a maximum of at least R300 a month ( total cost including line rental) ...is that even
possible?
I know the line rental will be expensive :/
i am currently paying for mtn uncapped mobile data at R300 pm and the speed is absolutely slow!
What speed are you getting on MTN at the moment, could you do a speedtest for us? : http://www.speedtest.net/
This package should work well for you : https://www.afrihost.com/site/product/capped_dsl_bundles?src=website_nav
The 2mb/s 50gb+50gb and it includes the line rental or if you need uncapped you ca go with this one : https://www.afrihost.com/site/product/uncapped_adsl_bundles?src=website_nav
But thats R97 more a month than your budget.... These are the cheapest i could find and ive used afrihost for a long time and been very happy with them. not sure if 2mb/s would be enough tho so maybe run a speedtest and post back :)
You won't get any ADSL below R400 a month. The analogue phone line is R160 or R170, and the 2 Mbps ADSL line cost another R170 per month. So that is already R340 per month without any ISP. Depending on your needs you can get a capped or uncapped account, but a 2 Mbps uncapped account starts at around R200 pm. So you have to up your budget to get ADSL.
Isn't there a 10GB cap on that MTN deal? After which they throttle you to very low speed? If you are using below 10-20 GB a month then ADSL is not really worthwhile.
Hi
possible?
Hi RVR
We currently offering the 1mbps premium all inclusive package for R339 which includes the 1mbps data + 2mbps line.
The 1mbps premium account has a threshold of about 100GB's for a 30day rolling window.
If you would like I could arrange for a consultant to call your with possible options.
Drop me a PM with your contact info and I could also arrange a free trial account for you at no cost.
That way you can experience the network for yourself and make an informed decision.
Hi RVR
And you still need the analogue phone line @ R170 odd, bringing the total back to ~R400.
Quote above includes a free Fon (i.e. hardware you'll need to connect to DSL) by the way. Six month contract etc.
