Need advice on diy project
Audiovisualdiyguy
HI
SO, I SALVAGED AN OLD TUBE TV, AN OLD DSTV DECODER AND A CCTV CAMERA. I WANT TO UTILISE THE CAMERA AT HOME, BUT NO DVR.
I TRIED CONNECTING THE CAMERA INTO THE ANTENNA INPUT (BEING ANALOG ETC), BUT NO LUCK.
SO I SAW ON GOOGLE, I CAN USE A VCR, BUT WONT A DSTV DECODER WORK TOO? IT DONT HAVE TO RECORD.
I JUST NEED TO TURN ON THE TV WHEN I HEAR NOISES OUTSIDE.
HOW DO I DO IT?
I would tell you, but then you'd have to change your username...
HI
HOW DO I DO IT?
Your TV should have an av input port. What connection does the CCTV require?
So your tv got no av input?
HI
HOW DO I DO IT?
https://www.gumtree.co.za/a-keyboar...ch-+-both-ps2-+-usb/1002134961030910427153909
Please get yourself a new keyboard - your caps key appears to be stuck.
