Hi
My line has been repaired after 2 weeks of problems where it could only sync with 1.2Mbps down and .5 up.
They have repaired that and it is back to 4Mbps down.
Since then my ping is realy messed up.
I used to have a 15ms ping to the IS gaming server now it bounces up to 200ms + and sometimes its back to 20ms for 5 minutes.
Even pinging www.telkomsa.net gives a high ping.
No downloads or updates are running at these times.
Should i relog the call - If Yes what should I logg the problem as.
