Need better picture quality with extraview setup
Gerrit377
Have setup a extraview with HD PVR 2P and 1131 decoder. Both decoders are in tv room. Have used 2x4 multiswitch, connected rf in to rf in. Rf out going to bedroom. The picture is a bit snowy in bedroom which i would like to improve. How can i improve it? Thanks
Why create a new thread?
The decoders have a UHF tuning which has a default around the 60 mark, adjust this down to 20 or 30, they need to be different so for example make one 24 & the other 28
Re-tune the TV
That should help a bit, otherwise it comes down to the cable connections & quality
Re-tune the TV
Does it work like the lower the frequency the better the quality? How would it work if i make the one on its highest and other on its lowest.
The lowest gives a better signal, not sure of the specifics why, QT might be able to
Try make them both low, just got dont one 25 & one 26 cos you will get interference between the two
Did somebody call my name? :D
Lower frequency, lower signal attenuation over RG6 cable... Why did you connect the in to the in, for the heartbeat? Doing it this way, you will not get a TVlink to work. Also, how far is the TV room from the bedroom?
