Need help connecting mikrotik to SAS-E
ptrut
You ME service has been installed, can you please configure VLAN 250 and connect your router to Port 1/1/8 on the SAS-E so that Openserve can do the final testing.
Im very new to this any help will be apreciated thanks
Peter
Should be pretty simple.
Go to Interfaces and click Add (+), select "VLAN", set VLAN ID to 250, select the interface the ME is plugged into (on the MikroTik) and hit Apply/OK.
Did they (Openserve) give you IPs to test with?
No they have not still waiting on ip's guess that is what had me confused .
Thanks for reply Ive already set up vlan.
On my Interface Settings Mikrotik Wich ip do i use and do i need do they have to give ma a default gateway? i think so just making sure
Thanks in advance
Your IP can be any one within those 6 usable IPs you have. The gateway is generally the first usable one within that subnet.
Drop me a pm if you get stuck. ill be glad to help if i can :)
