Need help converting 3dm file to other formats
kronoSX
Capetown home to gang stars
hi,i have a 3dm file which is a 3d vehicle i need for a project,I viewed the 3dm file in andriod and its half the object.it needs to be mirrored and put together.
I downloaded blender and sketchup and i just cant import this file to edit it.I searched google and tried importers..et..etc,They just not working:cry:I am really frustrated.
Can some guru please help me fix this by exporting my file to use in blender or sketchup format.
Rhino,autocad,autodesk 3dmax they are huge files ranging from 3gigs to 12gigs for the program adly i cant afford that data
I even tried a rhino viewer for windows to no avail,the only thing that worked was my tablet..lol.Please if there is a guru please help a buddy in need.I can upload the file in zip format to dropbox...etc
thanks
