Need Help Formatting and Reinstalling WinXP
charlieharper
South Coast, KZN
Hi.
I Have to format my HDD, "C:/" in order to Reinstall Windows XP obviously.
Now, my 250GB HDD is Partitioned into +-125GB each. So, I backedup all my files, pictures, ect to the other partition named "D:/"
How do I format and reinstall Windows on C without losing all my data on D??
Ok, This might be a noob question (hence i'm only 15)
I get:
Code:
To setup WindowsXP on selected item, Press ENTER
To Create a new Partition press C
To delete a partition press D
C: Partition1 (NTFS)
D: Partition2 (NTFS)
I dont see a option stating FORMAT, or am I missing it somewhere?
What should I choose, as I dont want to loose ANYTHING on D.
THX
which item is show as selected?
It should show C as the currently selected item.. just press enter to go to the next screen... it will then ask you if you want to format the selected item.
