TheRedDevil18
- Aug 26, 2012
Hi, I am planning on upgrading my computer. I cant decide on which card to take, the powercolor 7850 or powercolor 7870. I also plan on getting a motherboard, but not sure how much to spend. I am not planning on overclocking and so I am planning on getting an i5 4430. Here are my choices, budget of around R6500
Here are the links
http://www.wootware.co.za/powercolor-ax7850-2gbd5-2dhpp-radeon-hd7850-2gb-256-bit-gddr5-pci-express-3-0-x16-desktop-graphics-card-includes-2-free-games-amd-silver-tier.html
http://www.wootware.co.za/powercolor-ax7870-2gbd5-2dh-oc-radeon-hd7870-oc-ghz-edition-2gb-256-bit-gddr5-pci-express-3-0-x16-desktop-graphics-card-includes-2-free-games-amd-silver-tier.html
http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=30&products_id=6581
http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=11&products_id=10113
http://www.rebeltech.co.za/index.php?main_page=shopping_cart
http://www.mitabyte.co.za/pCO%20PV138G160C9K/Patriot-Intel-Extreme-Master-8GB-Kit-2-x-4GB-DDR3-1600MHz.aspx
My questions are, is it worth the extra R400 to get the 7870 or should I stick with the 7850, and also how reliable is rebeltech and wootware?, because this is my first time that I am buying with them. I live in Durban so they will have to deliver it. And also should I spend a grand plus on that gigabyte motherboard or rather go for a cheaper one?
Here are the links
