oh and it does the same thing when launched in the origin browser
okay so heres the deal after a few suggestions from u guys here on myBB im still falling short in playing the game....IT wont F#$%^&^ Run!!!!!!..lyk i said on a previous thread got the basics covered. after many failed installation attempts i finally got it installed and updated. went to battle log did that update game browser to, i then tried to join a server and it gave me a windows does not have access or permission and cannot find device path crap:wtf:...plz help
The only advice i can give you is reload your system and don't lock it down. Sounds to me like your windows install is not a happy camper. Have you loaded some security settings? You can sit and try this and that but it's just going to be quicker to reload fresh and install on a fresh system. You eliminate all possible issues in one go, seems like a mission but i find spending 5 days trying to fix something frustrating.
Sounds like you have security settings loaded. Is it windows 7?
I struggled the most with my install from the people here on MyBB.
I had to re-install windows from scratch to get it to work. Maybe that is your solution as well. Do a format of your HDD, re-install windows, load SP1 and SP2, Load drivers, re-install. Make a note of where your patch folder is. Copy the patch to a flash drive and when you do a clean install put the patch in the same directory.
It worked for me when I had to do the clean install, meaning I didn't have to download the 400 odd again. It would now be almost a Gig as yesterdays patch was also another 500 MB's almost.
Here's the thing the patch downloads through origin so I can't find it..unless u knw of a site where I can manually download and install the patch?
Yep windows 7 with no service pack I seen service pack 1 di I need that
K guys quick update EA help desk says its definately a security issue and what needed to be done was update windows 7 nt the service pack.do a fresh install of the game..so I did dat exept nw the update failed...I also turned my UAC off..there's this guy on the EA forum that says he has a fix but has to edit a certain file with risk of being banned from battlelog..sounds good
