slave
Hi all
A colleague of mine has a 100GB portable Lacie drive. He's been having some hassles with it and yesterday performed a standard windows quick format. I then tried loading some data for him but after a while the copy failed. It appears there are some bad sectors on the drive. Can anyone recommend a tool(pref freeware)/approach that will allow us to mark off the bad sectors so that the rest of the drive is usable. There is no data on the drive that needs to be recovered.
Tried a full format with windows but that seems to hang after a while. Have done a surface scan and there are definitiely bad sectors but don't have a way of marking them as bad.
Any help would be appreciated.
