I would really appreciate it if someone could me assist me as I have searched all over the net for a solution to my query and can not find a solution.
I have two seperate wired networks each consisting of 3 PCs that are connected in a workgroup via a network router. Each router inturn connects to its own DSL connection via a Mega 100WR router. I would like to connect these two networks wireless using the Mega 100WR access points as i am unable to use cable between the two networks. At present these two routers are only used to connect to the internet. I do not have any wireless devices connecting to them wirelessly. Can I configure the two Mega 100WR routers to see each other and link the two wired networks. If so could you give me a step by step explanation of how to do this. If this is not possible, what would I need to be able to do this? I have read that the access points must be set to bridged mode and I have done this but dont know how to go further. How do I get the two AP two see each other? Does the IP address ranges on the two networks have to be int the same (for example all in the 192.168.0.1 to 192.168.0.255 with a subnet mask of 255.255.255.0) range. What about MAC address where do I put these in?
I would really appreciate it if you could assist me with this problem, I a nube with all this wireless and only recently got my wired network setup
