LinkIT
Hi all, my 1st time on a forum.
I am from a small town, and we are busy to work out a plan to connect 4 towns together that is 70km, 80km, and 100km. stretches of mountains and plains.
Each town only has a maximum of 4 pc’s that will run on this backbone.
They will only use it for e-mail and a bit of internet, and then a telnet program will run live on the network from a server in the one town.
We did allot of research and gps measurements on all the points.
We made a hop of 40km at the most per tower,
We used 2 AP’s and 2 27dbi grids per tower. Each in a different direction.
I would just like to know if anyone thinks that we will have major problems with this type of long range, or if we set it up correctly that it will work.
I have all the specs of the equipment we will use.
Thank you
Thank you
