Need help with a shell script
w1z4rd
Karmic Sangoma
So I need to extract all the emails from one of the domains I have. There are roughly 2000 email accounts on this one domain. The server is a CentOS server with Cpanel loaded on it. I have two scripts to work with:
One using awk:
Code:
#!/bin/awk -f
# File: getAllEmail.awk
# This awk script takes the input of ls -d /home/*/mail/*/*
# checks to see if the directory exists, then outputs the email address. My example
# outputs them to a text file called emailaddress.txt
# I wrote it to get all the email addresses out of my cpanel box.
# You are free to use this program for your own purposes. If you
# improve it, please let me know. If it is horribly flawed, please let me know.
# Author: Hans C. Kaspersetz
# Date: 10/27/2007
# Email: hans [at] cyberxdesigns [dot] com
# Usage on cpaneli cli> ls -d /home/*/mail/*/*/ | getAllEmail.awk > emailaddress.txt
BEGIN {
tcmd = "test -d " $1
if(!system(tcmd)){
split($1,MyArray,"/")
print MyArray[6] "@" MyArray[5]
and one using PHP
Code:
#!/usr/local/bin/php
<?php
$folderlist = `ls -d /home/*/mail/*/*`;
$list_array = explode("\n",$folderlist);
foreach($list_array as $folder){
if(is_dir($folder)){
$folder_array = explode("/",$folder);
print $folder_array[5] . "@" . $folder_array[4] ."\n";
Now these scripts work great on all domains, except my largest one. Where I get the following error:
-bash: /bin/ls: Argument list too long
Anyone know how to break any of the above scripts up so I can safely extract the emails from the domain?
Change your command line usage, and run the awk script more than once. (how many depends on your usernames, and number of users):
Code:
usage:
ls -d /home/*/mail/[a-l]*/*/ | getAllEmail.awk >> emailaddress.txt
ls -d /home/*/mail/[m-z]*/*/ | getAllEmail.awk >> emailaddress.txt
Code:
usage:
That is sweet! ANd I know I will need to do the same sometime very soon so thanks.
I used the find command in the following format... but it still have errors but it got me closer:
Code:
for i in `find /home/ -maxdepth 2 -type d -name mail`; do ls -d $i/*/* | getAllEmail.awk >> emailaddress.txt; done
However, with all the commands I will still having issue with the biggest domain, so using advice here and in other players, I was able to extract the big domains email accounts with the following commands:
Code:
 ls /home/domainname/mail/domainname.co.za/* -d | getAllEmail.awk >> email.txt
Thanks for the help :D
icyrus is correct - find does not have the limitations that ls does.
simply:
find /home/*/mail/*/*/ -type d | getAllEmail.awk > emailaddress.txt
Will find all directories in the path, and pass to your awk script.
Could you not have just used:
find /home -type d -wholename '*/mail/*'
