graviti
I think Wolv is thinking about using SQL with a connection to SQL Server, or MySQL.
try
String user = myuser.getText ();
String pass = mypass.getText ();
// String sql = "SELECT COUNT(*) FROM LOGIN WHERE Username = '" + user + "' AND Password = '" + pass + "';";
// int count = rs.getInt (1);
String sql = "SELECT COUNT(*) AS Cnt FROM LOGIN WHERE Username = '" + user + "' AND Password = '" + pass + "';";
rs = stmt.executeQuery (sql);
int count = Integer.parseInt (rs.getString ("Cnt"));
System.out.println ("The result of the sql count is " + count);
rs.beforeFirst ();
rs.next ();
java.sql.SQLException: [Microsoft][ODBC Driver Manager] Invalid cursor state
try {
con = DriverManager.getConnection("jdbc:odbc:;Driver={Microsoft Access Driver (*.mdb)};DBQ=database.mdb");
stmt = con.createStatement(ResultSet.TYPE_SCROLL_INSENSITIVE, ResultSet.CONCUR_UPDATABLE);
rs = stmt.executeQuery("SELECT * FROM Table;");
} catch (Exception e) {
System.out.println(e.toString());
import java.sql.*;
Connection con;
Statement stmt;
ResultSet rs;
String GH = myuser.getText ();
Why are you getting the same value twice?
Can you upload your DB online?
Like this then?
Code:try { String user = myuser.getText (); String pass = mypass.getText (); // String sql = "SELECT COUNT(*) FROM LOGIN WHERE Username = '" + user + "' AND Password = '" + pass + "';"; // int count = rs.getInt (1); String sql = "SELECT COUNT(*) AS Cnt FROM LOGIN WHERE Username = '" + user + "' AND Password = '" + pass + "';"; rs = stmt.executeQuery (sql); int count = Integer.parseInt (rs.getString ("Cnt")); System.out.println ("The result of the sql count is " + count); rs.beforeFirst (); rs.next ();
There's no printout of:
Code:System.out.println ("The result of the sql count is " + count);
I can't seem to login to the database at all now, with incorrect or correct details. Still throws the same exception, though.
The code:
is merely for making a welcome message whenever the user logs in, i.e
User types: John White
John is obtained and placed @ top.
P.S Where would I be able to upload it easily?
Successfully connected to the database.
The result of the sql count is 1
Mybtn1 has encountered a error:
if (eve.getSource () == mybtn1)
lblnaam.setText ("Welcome to your profile, " + GH + " ");
//if printed out using System.out.println should view as follows, with sample username and password user:pass
// SELECT COUNT ( * ) FROM LOGIN WHERE Username = 'user' AND Password = 'pass';
try
rs.beforeFirst ();
rs.next ();
if (count == 1)
JOptionPane.showMessageDialog (null, "Redirecting you to profile management.. please wait a while.");
myframe.setVisible (false);
JOptionPane.showMessageDialog (null, "You are now entering your profile.");
JOptionPane.showMessageDialog (null, "Please be patient while stats are loading. . . . .");
myprofile.setVisible (true);
else
JOptionPane.showMessageDialog (null, "Incorrect. Please retry or contact a game manager.");
catch (Exception e)
System.out.println ("Mybtn1 has encountered a error:");
e.printStackTrace ();
Isn't String GH and String user the same?
Any filehoster such as Mega or Zippyshare
String user = myuser.getText();
String pass = mypass.getText();
if ()!(user.equals("")||pass.equals("")))
lblnaam.setText ("Welcome to your profile, " + user + " ");
try
Ssytem.out.println(sql);
System.out.println("Query executed");
if (rs!=null)
System.out.println("Query executed succesfully")
rs.beforeFirst();
System.out.println("Cursor moved before first record");
rs.next();
System.out.println("Cursor pointing at first record");
String temp = rs.getString("Cnt");
System.out.println("Result of query is " + temp);
int count = Integer.parseInt(temp);
if (count == 1)
else
catch (Exception e)
void DatabaseConnection ()
try
Class.forName ("sun.jdbc.odbc.JdbcOdbcDriver");
String filename = "E:/Java/2013/PatDB1.mdb";
String database = "jdbc:odbc:Driver={Microsoft Access Driver (*.mdb)};DBQ=";
database += filename.trim () + ";DriverID=22;READONLY=true}"; // add on to the end
// now we can get the connection from the DriverManager
con = DriverManager.getConnection (database, "", "");
stmt = con.createStatement (ResultSet.TYPE_SCROLL_INSENSITIVE, ResultSet.CONCUR_UPDATABLE);
System.out.println ("Successfully connected to the database.");
catch (Exception ex)
System.out.println ("Connection with database NOT successful");
ex.printStackTrace ();
public void actionPerformed (ActionEvent eve)
if (eve.getSource () == mybtn)
try
int cnt = 0;
String sql = "Select * From Games";
if (cmbo.getSelectedItem ().toString ().length () > 0)
sql = sql + " WHERE Genre ='" + cmbo.getSelectedItem ().toString () + "'";
cnt = 1;
else
cnt = 0;
if (cmbo2.getSelectedItem ().toString ().length () > 0)
if (cnt == 1)
sql = sql + " AND Rating = '" + cmbo2.getSelectedItem ().toString () + "'";
else
sql = sql + " WHERE Rating = '" + cmbo2.getSelectedItem ().toString () + "'";
cnt = 1;
while (rs.next ())
if (check.isSelected ())
if (cnt == 1)
for (int x = 0 ; x <= 130 ; x++)
String Genre = rs.getString ("Genre");
String Popularity = rs.getString ("Popularity");
String HighestScore = rs.getString ("HighestScore");
String Rating = rs.getString ("Rating");
String PlayerName = rs.getString ("PlayerName");
String TournamentAvailable = rs.getString ("TournamentAvailable");
String Game = rs.getString ("Game");
data [cnt] [0] = Genre;
data [cnt] [1] = Popularity;
data [cnt] [2] = HighestScore;
data [cnt] [3] = Rating;
data [cnt] [4] = PlayerName;
data [cnt] [5] = TournamentAvailable;
data [cnt] [6] = Game;
table.updateUI ();
else
break;
while (rs.next ())
cnt++;
table.updateUI ();
catch (Exception e)
System.out.println ("Vraag 1 onsuksesvol");
if (eve.getSource () == GetStats)
try
int cnt = 0;
String sql = "Select * from Profiles Order by HighestScore";
while (rs.next ())
double HighestScore = (int) (Math.random () * 5001) + 1;
double TournamentsPlayed = (int) (Math.random () * 251) + 1;
double d = HighestScore;
int r = (int) Math.round (d * 1);
double f = r / 1;
double g = TournamentsPlayed;
int m = (int) Math.round (g * 1);
double p = m / 1;
datas [cnt] [0] = Game;
datas [cnt] [1] = Double.toString (f);
datas [cnt] [2] = Rating;
datas [cnt] [3] = TournamentAvailable;
datas [cnt] [4] = Double.toString (p);
cnt++;
tables.updateUI ();
GetStats.setEnabled (false);
catch (Exception e)
System.out.println ("Profile Onsuksesvol");
if (eve.getSource () == quitbtn)
JOptionPane.showMessageDialog (null, "You will now be redirected to the main page.");
myprofile.setVisible (false);
myframe.setVisible (true);
if (eve.getSource () == mybtn2)
if (eve.getSource () == TNBTN)
myframe2.setVisible (false);
JOptionPane.showMessageDialog (null, "You are now viewing the Tournament Database.");
if (eve.getSource () == mybtn3)
JOptionPane.showMessageDialog (null, "To use this program effectively, please choose all fields respectively");
JOptionPane.showMessageDialog (null, "To search for games, fill in the Genre box");
JOptionPane.showMessageDialog (null, "To search for highest scores, fill in the Rating box");
JOptionPane.showMessageDialog (null, "To search which game has the highest population, sort by Population or just search with no fields attached.");
JOptionPane.showMessageDialog (null, "If you find any errors contact the creator to fix it asap");
if (eve.getSource () == myclearbtn)
int cnt = 0;
for (int x = 0 ; x <= 110 ; x++)
data [cnt] [0] = "";
data [cnt] [1] = "";
data [cnt] [2] = "";
data [cnt] [3] = "";
data [cnt] [4] = "";
data [cnt] [5] = "";
data [cnt] [6] = "";
cnt++;
table.updateUI ();
try
rs.beforeFirst ();
rs.next ();
if (count == 1)
else
catch (Exception e)
Have you tried replacing your code with the one I just gave you?
try
System.out.println (sql);
System.out.println ("Query executed");
if (rs != null)
System.out.println ("Query executed succesfully");
rs.beforeFirst ();
System.out.println ("Cursor moved before first record");
rs.next ();
System.out.println ("Cursor pointing at first record");
String temp = rs.getString ("Cnt");
System.out.println ("Result of query is " + temp);
int count = Integer.parseInt (temp);
if (count == 1)
else
catch (Exception e)
SELECT COUNT(*) AS Cnt FROM LOGIN WHERE Username = 'dsad' AND Password = 'dasd';
Query executed
at sun.jdbc.odbc.JdbcOdbc.createSQLException(Unknown Source)
at sun.jdbc.odbc.JdbcOdbc.standardError(Unknown Source)
at sun.jdbc.odbc.JdbcOdbc.SQLGetDataString(Unknown Source)
at sun.jdbc.odbc.JdbcOdbcResultSet.getDataString(Unknown Source)
at sun.jdbc.odbc.JdbcOdbcResultSet.getString(Unknown Source)
at Pat.actionPerformed(Pat.java:513)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Query executed
