Need help with digital music set-up for small bar
Ghost29
Hey,
I help run a small student bar at UCT. We are currently looking for a solution for the music for our bar. We basically want to be able to store and manage a large amount (250 - 500gigs) of music and be able to play it as playlists. We currently have an amp with a 4.0 speaker set-up and have an rca-to-stereo connector which we hook up to someone's mp3 player or laptop. This can be annoying as batteries run-out, people fade early or people just have crap music which can ruin a night.
There are a number of solutions I have explored. We have a TV right next to the bar which we can use as a monitor. I Ideally wanted to go for a netbook as its small size would mean it can easily fit under the bar (unlike a full laptop which is prone to spillage of drinks) but it is also easily stolen and probably a bit more than we need. I think that a cheap multimedia player will do which we can connect to the amp via rca and we can use the TV (via DVI) to manage it. Is this a good idea? Do you know of any cheap multimedia players with a good gui that might be able to achieve this?
A final option is probably to purchase an HP microserver and install something like open elec on it.
Thanks in advance for your advice.
My gosh, that is perfect. Any idea where I can get it affordably in SA? All I've been able to find is about 4.5k which is double the RRP for the US.
