Need help with excel formula/macro
werner
Hi Guys, excel newb here
Have an interesting problem (for me at least)
I have a list of numbers (prices), lets say A1 to A77000
I want to increase each price individually by a random percentage, but no less than e.g. 12% and no more than e.g. 25%
After this is applied, each price would have increased individually by a certain random percentage, but within the limits set above.
Ideas?
Can you clarify please?
what do you want as a final result, do you want random numbers between 12% and 25% of each number which you specified ?
random numbers between 12% and 25% added to the first numbers.
A1 is e.g. 10
so after this tweak, a1 becomes somewhere between 11.2 and 12.5
similarly, a2 also changes, but hopefully by a slightly different percentage..and so on.
It doesnt matter to me really if A1 remains the original value and the resultant addition ends up in B1 and so on......e.g. a1=10, b1=12.5
thank you in advance
Do you want fractional values in the range?
Can use RANDBETWEEN(min,max) but don't think it will give you a fractional random
hmmm, i hope i understand you correctly.
if cell A1=10 and A2 = 15 etc. then paste following formula in cell B1 and copy downwards etc
=RANDBETWEEN(($A1*1.12),($A1*1.25))
this will return a random number of the price in column A in column B
thank you guys....I'll run this on my sheet later today...
what an odd question, this seriously sounds like someone trying to generate a sample set that will reflect a predetermined position ;)
Good day
I wonder if you can help me.
I need to create a formula for my template
Column F contains ratings (R/A/G) and there is different Risk areas (column B). I want to colour column B according to the results in Column F.
For instance, say there is 2 Green and 1 Red, the colour in Column B must change to Amber (orange).
Is something like that possible?
Hope you can assist me.
