Need help with GNUBOX and N73
3Gee
I have sucessfully installed , GNUBOX on my N73 , problem is getting it to network with my PC , using a Netgear Router on a LAN ,here is a link for using GNUBOX with N70 , in my instance i am using MROUTER , there is initial contact with my PC , widcomm icon turns green , mrouter incon goes orange then blue , after few seconds , connection dropped
,http://crazylittleworld.com/2006/03/making-the-most-out-of-nokia-n70-part-2/
Have you had any luck?
Could you give a little help on installing gnubox on an n73?
