need help with internet sharing
thedutchman
Plettenberg Bay
hi guys, i've got a netgear modem and i supplying internet to my neighbours. Is there a way, that i can set it up, that i can check who uses how much bandwith ? cause yesterday we've been goin through 2.2 gb and that was on prepaid...
that could work, but thats a lot of trouble... isnt there another way ?
Its less conflict with neighbors. Everybody does their own thing & no fights over who chowed the b/w.
Monitoring it is going to be a bit of a mission.
And its not a lot of trouble. 10seconds max to change it.
lots more complicated - the best would be to setup a proxy server. you can then run reports on exactly who downloads what.
Try a custom IPcop server. All you need is an old pc. Then you can do more than just check how much cap they use.
www.ipcop.org
