Need Help With Internet (won't connect)
4cer
Does anyone know what it means if it says error connecting through wan miniport. the internet was working fine until last night whe i tried to connect and it just gives me this.
Any help will be greatly appreciated.
it sounds like you connecting with a router in bridged mode or a modem that needs a "dialup" connection from your pc? is this correct? or is it a router that handles the connection for you?
if it is a dialup thingy check your username and password are correct, or try setting up the connection again i am sure your isp could help you through the process
