Need help with mdadm
w1z4rd
Karmic Sangoma
So this is the story.
Client brings in centos linux server with 5 hard disks. 4 of the disks are in linux software raid and 1 of the disks holds the operating system. I am unable to boot up the server and need a rescue cd to see anything.
Using the following command I am able to recreate the raid array:
Code:
mdadm --create /dev/md0 -n 4 -c 256 -l 5 -p left-symmetric --assume-clean /dev/sda1 /dev/sdc1 /dev/sdd1 /dev/sde1
Normally at this stage I could just mount the raid array with the command:
Code:
mount /dev/md0 /mntpoint
However, when I try to this I get the following error:
Code:
The device '/dev/md0' doesn't seem to have a valid NTFS. Maybe the wrong device is used? Or the whole disk instead of a partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
None of the drives are NTFS drives, they all show as LINUX RAID when I fdisk -l.
Any suggestions? :(
Which version of CentOS?
Can you see the root filesystem? If so, check /etc/fstab
Maybe the md is a PV? pvs and/or pvdisplay will tell you
A better way to re-assemble mdadm arrays (without writing data to them) is:
mdadm -Es >> /etc/mdadm/mdadm.conf
Check what is in that file and then use mdadm --assemble /dev/md0 for example.
With mdadm --create you write data to the drives, and you never know but you might have created them incorrectly...
You have to however also check whether lvm was used to create volumes on them as well.
After assembling the drives, run:
vgdisplay
lvdisplay
to mount a lvm:
vgscan
vgchange -a y
mount /dev/$volumegroup/$logicalvolume /mnt/somefolderyoucreated
- replace $volumegroup with name from vgdisplay and $logicalvolume with name from lvdisplay
- there can be more than one logical volume you need to mount
you need the vgscan commands if you boot off a rescuecd or some livecd where the OS are unaware of the LVM stuff.
5.2 I think
The OS file system is on another drive. The 5th drive. It is separate to the raid array. This is a cat of my fstab
Code:
root@sysresccd /home/etc % cat fstab
LABEL=/1                /                       ext3    defaults        1 1
/dev/md0                /var/flexshare/shares   ext3    defaults        1 2
LABEL=/boot1            /boot                   ext3    defaults        1 2
tmpfs                   /dev/shm                tmpfs   defaults        0 0
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
sysfs                   /sys                    sysfs   defaults        0 0
proc                    /proc                   proc    defaults        0 0
LABEL=SWAP-sdb2         swap                    swap    defaults        0 0
Im not sure what this means. When I type pvs or pvdisplay nothing shows.
Also note. I am booted off a rescue cd in the mean time.
Other information. This is my fdisk -l
Code:
root@sysresccd /home/etc % fdisk -l
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00033916
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *          63  3907024064  1953512001   fd  Linux raid autodetect
Disk /dev/sdb: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Disk identifier: 0x00056c82
/dev/sdb1   *          63      208844      104391   83  Linux
/dev/sdb2          208845     4401809     2096482+  82  Linux swap / Solaris
/dev/sdb3         4401810   488392064   241995127+  83  Linux
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x00076244
/dev/sdc1   *          63  3907024064  1953512001   fd  Linux raid autodetect
Disk /dev/sde: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x000b5173
/dev/sde1   *          63  3907024064  1953512001   fd  Linux raid autodetect
Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x000955c5
/dev/sdd1   *          63  3907024064  1953512001   fd  Linux raid autodetect
The Ubuntu server CD in rescue mode is useful (even on non Ubuntu installs).
It automatically detects software RAID setups and LVM volumes when you boot so you don't need to fiddle with mdadm or the LVM tools by hand.
Just boot to a rescue shell and mount the file systems.
To reassemble a RAID array I always use the --assemble option.
Doesn't --create try to create a new RAID array? :wtf:
When I try create the raid from the rescue cd with the following command... everything looks alright:
Code:
root@sysresccd /home/etc % mdadm --create /dev/md0 -n 4 -c 256 -l 5 -p left-symmetric --assume-clean /dev/sda1 /dev/sdc1 /dev/sdd1 /dev/sde1
mdadm: /dev/sda1 appears to contain an ext2fs file system
    size=1565568512K  mtime=Wed Jul 18 05:51:09 2012
mdadm: /dev/sda1 appears to be part of a raid array:
    level=raid5 devices=3 ctime=Tue Aug  7 10:58:27 2012
mdadm: /dev/sdc1 appears to be part of a raid array:
    level=raid5 devices=3 ctime=Tue Aug  7 10:59:17 2012
mdadm: /dev/sdd1 appears to be part of a raid array:
mdadm: /dev/sde1 appears to contain an ext2fs file system
    size=491826688K  mtime=Wed Jul 18 05:51:09 2012
mdadm: /dev/sde1 appears to be part of a raid array:
Continue creating array? y
mdadm: Defaulting to version 1.2 metadata
mdadm: array /dev/md0 started.
However, when I mount it... this is the part that is pwning me
Code:
root@sysresccd /etc % mount /dev/md0 /mnt/raid
NTFS signature is missing.
Failed to mount '/dev/md0': Invalid argument
Uhm, you created the array as a raid5 array, however there are 4 drives, are you sure it was a raid5? Raid10 sounds more plausible with 4x drives.
According to this it is raid 5
Code:
root@sysresccd /etc % mdadm -E /dev/sdc1
/dev/sdc1:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 528ac1ec:baedc77e:47eb854c:97fa539e
           Name : sysresccd:0  (local to host sysresccd)
  Creation Time : Tue Aug  7 11:15:03 2012
     Raid Level : raid5
   Raid Devices : 4
 Avail Dev Size : 3907021954 (1863.01 GiB 2000.40 GB)
     Array Size : 11721063936 (5589.04 GiB 6001.18 GB)
  Used Dev Size : 3907021312 (1863.01 GiB 2000.39 GB)
    Data Offset : 2048 sectors
   Super Offset : 8 sectors
          State : clean
    Device UUID : a67ec651:635b43aa:bdb65c46:c8dd309e
    Update Time : Tue Aug  7 11:15:03 2012
       Checksum : 2834163f - correct
         Events : 0
         Layout : left-symmetric
     Chunk Size : 256K
   Device Role : Active device 1
   Array State : AAAA ('A' == active, '.' == missing)
vgdisplay
lvdisplay
to mount a lvm:
vgscan
vgchange -a y
Code:
root@sysresccd /etc % vgscan
  Reading all physical volumes.  This may take a while...
  No volume groups found
Looks like either the RAID5 was a 3 disk array with 1 hot spare or the Array went degraded and forgot 1 of the disks after the failure
Either would explain the problems mounting the Array as NTFS storage ( even though you may have all the disks the order may be off or your RAID info may be incorrect when you try to create the array ) or you may actually have been using it as LVM
If anyone thinks they can fix this. Im willing to pay :D Can create shell access.
Can you do mdadm -E /dev/sdx1 for all the drives,looks like the RAID order is wrong too
Code:
root@sysresccd /home/etc % mdadm -E /dev/sda1
/dev/sda1:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : d64adeed:f6341697:ece61d83:b199f55f
       Checksum : afa4a819 - correct
         Events : 0
     Chunk Size : 256K
   Device Role : Active device 0
root@sysresccd /home/etc % mdadm -E /dev/sdc1
/dev/sdc1:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
         Events : 0
     Chunk Size : 256K
root@sysresccd /home/etc % mdadm -E /dev/sdd1
/dev/sdd1:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : f3370d67:d83fdcef:97e34af8:157f0798
       Checksum : 2ed8822a - correct
         Events : 0
     Chunk Size : 256K
   Device Role : Active device 2
root@sysresccd /home/etc % mdadm -E /dev/sde1
/dev/sde1:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 7854e1ed:20c0c20f:7752997a:e4dd84f5
       Checksum : b55eeca6 - correct
         Events : 0
     Chunk Size : 256K
   Device Role : Active device 3
Thats all of them.
Code:
Using --create instead of --assemble was likely a mistake, and might've hosed your data.
Notice this bit:
Code:
Makes me agree with one of the other posters that it might've been a RAID5 with a hot spare.
You wouldn't happen to have mdadm -E output from before the mdadm --create?
The ext2fs on sda1 and sde1 in addition to the raid component is puzzling though...
Notice this bit:
Code:
Ive had this problem before. Actually earlier this week. Where I used that create command to be able to create the raid array. Mount it and recover it. The mdadm -E is pretty much the same.
I was following the instructions as per here: http://wiki.centos.org/fr/TipsAndTricks/Repair_RAID5_Volumes
Whats worrying is that level=raid5 devices=3 that's now mounted with 4 devices,and this is also why I hate RAID5 passionately
You may have hosed this array somewhat now doing a --create,you should be using --assemble flag first to see if you can connect to the existing array ( if the superblocks are untouched usually this is enough to access the array when mounting )
If it was a raid5 array, recreating it as a raid5 wouldn't screw up the data, however if it was a raid10 and he created a raid5 over it...that is where the problem comes in. Never use the create command when you don;t want to lose data.
Do you have output form "mdadm -E" from before you used --create the 1st time?
If you seriously need to data on the array and you can't build the array correctly using assemble take a windows desktop with 4 spare SATA ports
Install windows xp or 7 on it,grab Reclaime have it scan the disks to retrieve the original raid configuration,then use R-studio or similar to create a virtual array and start recovering data
*Caveat - this may take a few days worth of scanning
I've had a few RAID5's fail so i've done my fair share of rebuilds
