Hello,
Can someone give me some advice please - because I need my car fixed, and I dont want them to rip me off again. I at least want to know what is wrong, so they dont fix all other stuff that might cost money.
Now, my car engine is very loud when I drive, louder than normal, it actually makes this kinda grinding sound, as if its really driving hard, and its not running smoothly. Especially when I drive fast (120) the car shakes and the engine noise is very loud. When I then stop at a robot, my car like vibrates alot, but then i switch it off and on again, and it kinda runs smooth again. There is oil in, but can the engine be loose or something? Its as if its got trouble driving.
then, my brake discs needs to be replaced, cos it makes a sound when I break, like a "skaaf geluid". Can this be the problem why its driving so weird?
Then, where can i go thats reasonable to fix this breaks? They need to drill a fith hole in the disc break, cos I got other rims on my car. Is there a place in CPT thats not expensive?
Further more, my handbrake light is permanently on, it doesnt want to switch off.
can someone PLEASE give me some advice regarding the above?
thank you so much!
nicci!
thank you so much!
nicci!
