Plasticmonkey
Hi guys
So I have been having trouble with my PC the last few days. Operations freeze for no apparent reason, and my PC takes like 5min to startup.
I decided to do a format this moring, thought it would solve all my problems, boy was I wrongg.
I have a seagate 1000gb SATAII HDD. The HDD s partitioned into one 50gb drive (for XP) and one 950gb (for the rest)
This morn when I tried to format, something very wierd happened. Apon booting from my XP cd, setup refused to delete my XP partition. It said, "cannot delete partition"
I tried running setup like 8 times with the same result.
Ive also tried fiddeling with the sata cables, using other ones, as I thought it might be the cable that was faulty-no luck.
The HDD is in an excelent condition, placed in a well ventelated box. I ran S.M.A.R.T the other day, and my HDD came back 99% fine.
I tried putting the HDD in another PC, to format the xp drive via computer management. Windows can see the disk, its there, but each time I try to format, it says "format failed"
How can I fix my problem???
Is there any other apps that Might help me to format this drive?
Please guys, im not too keen to lose close to 1000gb worth of stuff, so please help!!!!
