Need help with my SANZB Disc error issue
Acid0
Johannesburg
I have an issue all of a sudden.
For the past four months had no issue with my SANZB but from last night I had a disc error issue in my warnings.
It will start downloading and every time it needs to put a part of the file down in the folder it hits up a warning and pause the complete download.
The two errors I get every time is the following.
"Disk error on creating file C:\Users\Download\Documents\Downloads\incomplete\Foldername\filename.r00
Saving C:\Users\Download\Documents\Downloads\incomplete\foldername\__ADMIN__\SABnzbd_nzo_j61vkb failed
It looks like it is the temp folder it copies the files across before it moves it to the correct folder specified in the categories section.
I dont know if it might be permissions related.
Is it maybe a setting that I need to change in a config file or what is the options I have?
Last resort will have to be to uninstall the SANZB client and try to reinstall it again.
Thank You
I had a similar issue a while back, something to do with the path and file name being too long. Try changing the download location to c:\Downloads before you reinstall.
Thank You
The path is too long, change the folder to something not so long.
