Need help with MySQL grouping
DrJohnZoidberg
Table View
I cannot seem to get this one figured out fully.
I need to group records together that fall within a certain time period, for instance all the records that were added within an hour of each other.
Let's say I have theses records:
Code:
USERNAME POINTS DATESTAMP
USER1    50     2014-01-16 23:59:03
USER1    22     2014-01-17 00:01:04
USER1    16     2014-01-17 00:19:17
USER1    11     2014-01-31 15:12:00
USER1    34     2014-01-31 15:19:34
I want to now get these grouped so it should look like this:
Code:
USERNAME POINTS
USER1    88
USER1    45
As you can see the first three records all fall within an hour of each other and the last two also do but on a different day.
Grouping by day wouldn't work, because the one date is on the previous day.
Any help would be appreciated.
GROUP BY DATE_FORMAT(date_field, '%Y%m%d%H')?? That format probably isn't 100%
Thanks, but that doesn't solve the issue because I'll still end up with two separate groupings for each day and hour:
201401623
201401700
My Google-fu is off, cannot seem to find anything on how to do this.
201401623
201401700
So don't use the day parameter in the format, or won't that work for you?
Not if you leave the hour parameter...
I'm realising now they way I want it creates problems. It needs to know where the starting point is somehow, I need to figure that out before I carry on.
Will update when I get something.
Use a temp table to insert username & points that qualify the time condition, then group select from that
Do you want to group by hour or what?
No, I don't want to group by hour. I need to group records that fall within an hour time range of each other. Simply grouping by hour won't work because one record can be added 13:59 and the other at 14:02, different hours but only a few minutes apart.
Yeah that's not going to be as simple. If you have 3 records, you can have 2 pairs within an hour of each other.
You could probably make use of the previous and next record and do a calculation using something like DATE_SUB then group on the result.
But how must it know which record to use as the "Base/Starting" point.
I.E
USER1 50 2014-01-16 23:10:03
USER1 16 2014-01-17 00:59:17
You will end up with
USER1,72
USER1,32
So record 2's points is now shared with record 1 and 3.
Record 3 is < 1 hour compared to record 2 but > than 1 hour compared to record 1.
Yep. I need to figure this out somehow :(. Thanks for the input so far.
You need to think 2-dimensional. Set up a matrix of times. If you want, I can see later if I can figure this out in SAS.
How many records should we expect in this database with the points?
