Stuff like this should be stickied or put in the OP. Would make life so much easier. Been searching for something this for months...
Okay read Post # 374 in that thread. You will not get easier step-by-step instructions than that.
http://mybroadband.co.za/vb/showthread.php?t=39234
Here is how I did it:
1: Set your router to "Bridged Mode"
2: Open Regedit, navigate to "HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\C lass\{4D36E972-E325-11CE-BFC1-08002BE10318}\0002", change the value of "Wanendpoints" to "2"
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Control\C lass\{4D36E972-E325-11CE-BFC1-08002BE10318}\0002", change the value of "Wanendpoints" to "2"
3: Close Regedit, and restart the PC.
4: Go to: Control Panel -> Network and Internet -> Network and Sharing Center and click on the left side where it says: "Set up a connection or network"
5: Select "Connect to the Internet: Set up a wireless, broadband, or dial-up connection to the internet." Click Next
6: Select "Broadband (PPPoE). Type in your Username and password and tick "Remember Password". Type in "Local Connection" for the Connection name. Click "Create". It will test the connection and if everything is working, it will connect to your local account.
7: Go to "Network Connections" and right click on your local account. Select "Networking -> Properties -> Advanced." Deselect "Use default gateway on remote network". Click "OK" 3 times. Close all windows.
8: Go to: Control Panel -> Network and Internet -> Network and Sharing Center and click on the left side where it says: "Set up a connection or network"
9: Select "Connect to the Internet: Set up a wireless, broadband, or dial-up connection to the internet." Click Next
10: Choose "Set up a new connection anyway", Choose "No, create a new connection" and press "Next"
11: Select "Broadband (PPPoE). Type in your Username and password and tick "Remember Password". Type in "International Connection" for the Connection name. Click "Create". It will test the connection and if everything is working, it will connect to your International account.
12: Install Routesentry and run as Admin.
13: Connect Local and International through Routesentry if already not connected.
14: Press "Set up routes now". It should now work
