Need info please regarding an APC Smart UPS Unit
PaulB_
Hi all
Firstly want to say, that this isn't related to my previous posts, that was with my personal power backup.
This is in relation to my work.
We have a UPS in our server room, and from what I can see it's a reasonably high end UPS, and it's built like a tank. The server has since been decommissioned, but the UPS still sits there, and my aim would be for it to run our ONT, and internet for the admin department. I had it set up to run our ADSL, and switches, and even then the unit would shut down after barely an hour.
What I don't know however are the technical details, of the wattage, and if it's one of those "It's only there to allow you to safely shut the PCs down after a power failure" type UPSses, or if it should by design carry us over till the electricity comes on again. I also don't know how long the batteries should be expected to last, however what I do know is that batteries are most likely almost 10 years old, and most likely need to be replaced. I have attached a photograph of the UPS, and Quality control slip, as hopefully that should lead to some answers.
