Here is a link for version 5 of it...
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Samsung-Recovery-Solution.shtml
101 MB - don't think so. It's probably only the windows front end.
I thought that what he wanted ? The Samsung Software, not the image... my brain is tired... need recharging.
I use Acronis and have had it bomb during an image restore a couple of times... what is left is a partition in an unusable and hidden state... once this has been corrected, the restore can continue.
I think the biggest hurdle for the OP at the moment is just getting Acronis to see a partition other than D: to which his .tib image can be restored to.
Shout if I am not correct raycomp.
The scenario has now changed. I have tried all the options and are now screwed. I don't see the drive now at all. I have added it to a external housing connected to PC. Windows 7 picks up the USB device, I hear the drive spinning but explorer does not show the drive at all. Only the PC's C: D: and E drives appear in explorer.
If I put it back in the laptop it just says Boot from AGCI CD-Rom. Software for my laptop was on hidden partition s I do not have a bootable disk. I used the Acronis bootable disk that I made on a suggestion from someone here then is sees the disk. If I use the Add New Disk option it shows Disk1 232.9GB Serial ATA 232.9 Unallocated. it is a 350gig drive. I did not done anything further. Question now is can I recover my disk if the PC does not show it or is the data now unrecoverable and should I continue to use Acronis to add the disk and see what happens
Thanks for the prompt reply. Luckily I have the image.tib on an external drive. If any file required, even if Acronis can't fix then at least I will be able to recover required files from the image.tib
Once again thanks
I managed to reload windows and recovered my .tib file.Recovered the backup and laptop up and running. Once again thank you.
quick question how do I mark this as resolved?
