Hi
As per a previous thread I started today, our town and it seems area had a network problem today, lines would sync, but no PPPoE connections could be made. I confirmed that 2 people I know who have ADSL experienced the problem we did.
The strange thing about this (Garyvdh is going to have a laugh), this afternoon when I tried to use the internet, I would be able to use it for about 3 minutes, or just a few sites, then the connection would die. I saw it died in the router as well, the router just stayed on "connecting".
I managed to narrow down the problem this morning to the fact that it's my Toshiba laptop's wireless that is "refusing" the router to connect.
I have a Billion 7300M using the latest Firmware (07/2008).
I am using WPA2-PSK AES encryption and my ESSID was usually hidden, but for some reason my laptop refused to connect today so I changed the setting to show it.
The narrowing down of the problem was basically this:
I sat for close to 15 minutes, listening to music and looking at the router Logs and the text that said "connecting". I decided then to disconnect from Wireless, waited a minute or two then I connected via wireless again, all of a sudden the internet connection was connected. I doubt it's just coincidence. The wireless connection is causing the router to drop the PPPoE session and won't allow it to reconnect. I restarted the pc previously as well (Garyvdh, lol) and then the internet was connected for a few minutes.
My memory is poor and after upgrading the Firmware on the router recently, I could not remember which channel number I used before when it worked fine. I've switched between channel 6,9,11 and 13, I'm currently on channel 9.
I use Europe regulation domain on the router.
I've got the Toshiba and my brother has an Acer with wireless as well, running XP, so I have to find a common ground so both laptops can be on the network.
Sorry for the long post, but I tried to be as clear as possible.
Any help or advice would be appreciated.
tera
Edit: seems I was able to type this whole post and submit it with the connection being stable.
tera
