need some gear+gen advice for me lock
Nickd
hey all
struggling to get my crit to a respectable level because also worrying about maintaining the hit cap of 202...
nickd
Shadow damage is at 1130 self buffed, where should i be looking to get new gear from? and also what slots should i need to aim for?
thanks!
Your Crit isnt too bad ,21+5 % not bad at all
You could raid MH and BT , if u can find a guild
Otherwise get more badges and get teh doomguard gloves (or whatever) from isle badges
And fix the pvp mainhand
Use www.maxdps.com and Ull see once you reach 1400+ shadowdam with consumables, buffs and wrath totem ,haste will out scale +dam
Also try get the blessings mooncard trinket ;) and dont use gems to get ur crit up;)
I also see ur using immo-incinernate-conflag thats a big nono
SB spam all the way it scales betterwith ISB. Conflaging in PVE is a huge nono
i have the blessings trinket, i just need the airmans ribbon of gallantry on there for the crit :/
i dont use incinerate at all, but i do use conflag to deal a quick 1.5k damage just before immolate runs out :P
thanks!
I highly recommend you do not immolate at all!
Simply if your on curse duty put up ur COS/COE if ur not then COA
and spam that SB throu your keyboard:)
http://www.wowhead.com/?talent=IZdxczIbzZEx0trozhhi this is what I use
Theres no need for emberstorm ,improved Immo and conflag
I would rather use those points on soul leech ,backlash and most importantly nether protection
The idea is rather cast another SB than keep immo up and conflag it( hence using up a tick and wasting mana)
Spamming SB and keeping the ISB debuff(shadow Embrace) up keeps the dps throu the roof
Its kinda hard for a Loc to let go of his dots iknow, but it gets exciting when you SB's start critting 8k :D
crap .. immolate is great combined with SB .. but hey what do warlocks like buzzkill and clinkz know? use it ... dont use it.
skip conflag , but not imm.
Lol
I have some nihilum vids and i cant see them use it ,i have a look tonight
Serias You sacrific ur succy for 15% Shadow buff and waste ur time keep immo up
Edit: they probally do it cause of t6 set bonus-.-
2nd: http://www.youtube.com/watch?v=fKVyzdeFDr8&feature=related
here SK gaming downing kiljaeden jump to 3:15 and its their loc POV. He doesnt use immo.
3rd: http://forums.wow-europe.com/thread...E44F6D4FAF2.app09_04?topicId=3350025179&sid=1
The only time i use immolate is when the fight is just started to avoid a big crit and insta-aggro. 1 on an entire fight. As 21/40 ALL talents in fire is worthless since you wont be using it without gimping your dps. So many think that 21/40 is a firebuild and guess what it isnt. The only point in fire needed is 1 in emberstorm just to get down to the next tier.
Casting Immolate reduces your DPS in a 21/40 Shadow Destruction build. It's been posted here many times before.
Read the whole thread
Try search more threads you find that immo does not increase your dps
