Need some help with SQL.
Pho3nix
The Legend
On the toilet
Hi guys,
I'm trying to filter data on a SQL view depening on whether eg. ID ends with 25.
Now because this isn't text wildcard search isn't working, I'm a little stumped on how to do it? Any advice ?
Hi guys,
Try something like (ID % 25) = 0 - basically ID divided by 25 returns no remainder ;) - must mean it ends on 25 ? I can't think of a number that ends in 25 not divisible by 25 .. ?
That would catch multiples as well, eg. 50, 100.
Cast the ID to a to a varchar and then use LIKE '%25'
Not so efficient but should work.
Code:
WHERE cast(ID as varchar(?YourLengthHere?)) LIKE '%25'
You dont have to cast it as a varchar to do comparision. Something like:
SELECT *
FROM YourTable
WHERE ID LIKE '%25'
Will just work even if ID is an integer or a real
*EDIT ^As the above says
My or TsOx's methods would suffice as we're looking for a string match using a string operator on a field. Complicating it with modulus for no real reason ;)
You may experience a performance penalty if you use LIKE instead of modulus
Using modulus for a like is more likely to be a table scan operation,whereas LIKE with a wildcard at the start will likely trigger an index scan which while slow is faster than table scan
*Note assuming your table is indexed. If not there will still be an overhead for a math operation or a string comparison,the speed of these will depend on a few things like math-coprocessors
Would need the single quotes,but yeah workable,similar performance hit
Thanks guys, don't know where my head was at :o
Tried using
Code:
LIKE '%[37-40]
to find a range but this didn't work..
Hi Guys,
Now if I for example wanted to only select sales that occured on the weekend how would I do that? :\
Ex: select * from table where salesdate >= '12/11/2011' AND salesdate < '14/11/2011' ?
If column has date type
I think i have figured it out.
Code:
DATEPART(DW,saledate) IN (7,1)
