Need some info
Qrox
Pretoria
Hi guys. I'm currently with Iburst and want to switch over to ADSL in the new year. (Tired of iburst service going backwards instead of forwards).
On Iburst I get a download speed of 100kbs. Now what I want to know is: I have been looking at a ADSL offer from SAOL http://www.saol.com/ (R499p/m for uncapped ADSL on a 384k line). Can anyone tell me what download speed you get on this line and about how much ping you get on Wow and Modern Warfare 2?
I need all the info before I can deside if this is for me or not. Would really appreciate help.
You can work out the "maximum" download speed by dividing the overall kbit speed by 8. Thus, a 384k/bit line would give you a download speed of around 40k/bytes per second. Your latency will depend on your proximity to the exchange, among other things. Speed of the line does not influence latency - but I can pretty much assure you it will be better than iBurst. You're probably looking at anywhere from 400-800ms on WoW.
thats right. expect between 38k and 40k a second max download.
latencies should be better than iburst and you can choose between many different isp's compared to just the on with iburst.
I was hoping for a bit higher download speed but heck, at least then it's an ancapped account :D
If you are looking to play WoW, I recommend investing in an unshaped account as well - will drop your latency to around 250-350ms.
Where can I get that and how much does that cost? Also exactly what benefit will I be getting from an unshaped?
AFAIK the SAOL accounts are unshaped if I remember correctly from reading that thread.
In a nutshell:
Shaped = optimized for HTTP traffic.
Unshaped = No port shaping is put in place. (for non standard ports such as FTP, Remote Desktop & many gaming apps etc)
which offer btw, the R499 one?
btw, the terms read-
This offer is subject to the signing of a 24 month contract. A set-up fee of R1500.00 is applicable and the preconfigured router is on loan for the duration of the use of service.
SAOL & Cybersmart will offer you that for around R500 including adsl line rental.
Anybody that goes for a 24month contract now must be mad!
I think I have changed my ISP about 4 times now in the last 6 months.
