need some smart techie's help!
Subversion
Hey guys,
Got a rather odd laptop mystery I was hoping someone could help me with.
My girlfriend has one of the new Sony Vaio (S-series I think). We are both living in Korea at the moment and we bought it here. She's only had it for a little over a month (its one of the new ones with a Core i3 and DDR3 memory, etc).
The problem is the screen brightness. It's not dark, its just... dim. The way a laptop looks when its running on batteries, thats how it looks when its plugged in. I've adjusted all the power saver settings in windows, no change. I've pressed Fn + F5 to toggle up the brightness, but the bar moves up and down and no change in brightness (less or more).
When the computer boots into windows, it goes bright for a few seconds, and then it goes back to being dim. If the screen goes to sleep, when you wake it up again it goes bright for a couple of seconds, then goes dim again.
Is this a hardware or a software problem? Should we take it back? Any help on this frustrating problem would be very, very much appreciated.
Are there any brightness settings in the graphics card driver panel?
I don't know the sony's but it is a sensor that automatically adjusts the brightness, try FN and the left arrow or something to turn it of and force a static brightness setting....
Check the bios.
Or "go to the Sony Vaio Control Center from the Start menu, Click on the Display Icon and then select Automatic Brightness Settings. Uncheck the "Adjust Brightness Automatically" box."
ah man, rudimental thanks so much that control center did the trick. its a korean notebook so everything is a little foreign hehe.
thanks a lot man, and thanks to everyone who replied.
