Need some urgent help - RECOVERY MODE!
Cassady
Die Kaap
Sorted - Recovery mode.
Hello all,
Been having some fun and games installing a SSD into my mid-2012 MBP of late, and things have now finally come to a head.... :confused:
A short recap:
1.) Cloned HDD onto SSD with CCC;
2.) Installed SSD into optibay;
3.) Rebooted into SSD - and things simply weren't stable.
4.) Switched HDD and SSD - given a variety of forums that suggested the 2012 sometimes has issues with the SSD in the optibay.
5.) All appeared to be golden - barring the rather bizarre fact that my date and time remained out of synch - which I overrode manually.
6.) Formatted HDD, moved media over - setup iTunes; iMovie and iPhoto libraries, all relatively easy and fuss free.
As it stands - Mac still takes as long as what it used to, to boot up to the point where I enter my password, but after that - everything flies. Beach-balling has stopped - since Spotlight indexing is done. In short - everything looked perfect, with me being blown away by the speed of apps opening on the SSD! :)
So then I decide, one last time - to finally check everything, and ensure that those Permissions errors [after running Disk Utility] I kept getting when the SSD was in the optibay, were finally gone - I run Disk Utility again.
This time I decide to Disk Verify the SSD - it checked out perfectly when the SSD was in the Optibay.
And then I get this: :sick:
I CMD+R rebooted, and got to the Internet Restore option. Which suggests(?) that CCC never installed a Recovery Partition (which is odd, since I'm pretty sure it did?).
I cancelled, and switched on and off - ran Disk Utility again, and attached the screen grab above.
Questions:
1.) Do I let it do its thing, and connect to the internet, and download what it needs to?
2.) If so - does this allow me to simply boot into Disk Utility in Recovery Mode, to try and repair the disk - or is there a chance that it might wipe the SSD?
3.) In the absence of 1 & 2 - what are my options - particularly in light of the fact that, Disk Repair message aside, all appears to be running brilliantly?
I would really appreciate some tips here....
Did you ever make a USB installer? I remember you asking about this a while back. It should have the Recovery (for Disk Util) bits available.
Oh my word - yes I did! Clean forgot about that? Do you mind explaining briefly how I would launch into it - opt+reboot?
Yes, reboot holding down opt key, and you will be able to boot from usb drive.
And move the SSD from the optical bay to the normal drive bay. If you want two drives in there then rather put the spindle drive into the opti bay, it apparently effects performance.
Thanks. Did that this morning. Worked 100% and I thought I was golden - then the disk verify issued jumped up.
Launched into Disk Repair off my Recovery USB - it's doing it now...
Think this is a good sign: "The volume GF SSD was repaired successfully"...
Thank all that is good and holy.
Still busy with "Updating boot support partitions for the volume as required"....
Doubtful - both SATA ports are identical on the newer (at least post 2010) machines. You can by looking at the link speed (nb not the negotiated speed) in the system profile. Both should read Link Speed: 6 Gigabit.
There are some doubts at the the efficacy of Apple's built in sudden motion sensor on any bay other than the original HDD bay. Whether or not that is true is one thing but why take the risk if there's no performance hit?
EDIT - dont forget the HDD bay is dampened for sound and shock. ;)
Doubtful - both SATA ports are identical on the newer (at least post 2010) machines. You can by looking at the link speed (nb not the negotiated speed) in the system profile. Both should read Link Speed:6 Gigabit.
Bwana - did a fair amount of reading yesterday, about whether the problem could be caused by my SSD being in the Optibay - since if it was at all unlikely, I would have left things - not wanting to open up the MBP again, and swap both of them unnecessarily....
I too was certain that either/or worked on my particular model, with the motion sensor having it as preferable to keep the HDD in the original place.
This being said - several user comments had me open it up and swap - current issue aside, and it might have been purely coincidental - but it instantly stopped giving me problems. It was completely stable. Not saying anything other than in MY mid-2012, stability improved when I swapped them round.
Thank goodness for Google - would have been waiting an awfully long time for the "Updating boot support partitions for the volume as required" to finish! :D
Going to reboot now and check things.
Many thanks for the help - and adding a fair amount of credibility to my wife's suggestion that I'm developing the memory of a goldfish... :P
Remember, you still won't have a recovery partition until you reinstall the OS so don't lose that USB stick.
Just been put in place of safety. I guess with the usb working fine, I shouldn't worry about re-doing everything - or are there some features that would make a partition on the actual Mac preferable?
I find having it on the USB preferable as a hardware
failure on the HD can kill you in that case. OT: bwana that tool I have criticized Disk warrior managed to do something nothing else could: rebuild the volume header on an otherwise bombed HD so reservations held back for now.
All running smoothly today - things back to normal.
Boot up speed is still quite slow, until after I've entered my password - then it absolutely flies! :)
Was an SSD worth it?
i.] More storage;
ii.] Instant loading of apps;
iii.] Zippier all-round performance between desktop | spaces | exposé etc.;
iv.] Much, much less time simply "waiting"...
In short - absolutely!
FWIW - a few things I have learnt:
a.) A Disk Repair | Disk Permissions Repair or something similar in Disk Utility, is not unnecessarily a train-smash, unless Recovery Mode's Disk Utility cannot fix what has been reported...
b.) I need to overreact less. Yesterday was most certainly a knee-jerk reaction from years having to reinstall Windows etc. etc.,** following some sort of system-deep error... I had visions of being off-laptop for days - in the end, it was a minor speed-bump.
c.) One can never have too-many backups.
d.) The Recovery Disk on a USB - and how it is utilised by Mac OSX - absolutely rocks!
e.) I need to overreact less! :)
Thanks for the help yesterday.
** I am currently in the throws of reinstalling Windows on my VM - since a P.I.C.N.I.C. | Parallels 8 | Win7 | Office 2013 | Outlook IMAP vs POP exchange stuff-up has me and IT without any answers... Some things never change.
I have both available ;) Additionally I have a rescue partition already on my cloned drive so in the eventuality of a drive failure it's ready willing and able to take over.
