Hi All
I'm at the stage where I'd like to upgrade my computer but I'm fairly clueless as to where to go. My current problem is as to whether I should move to an i5 or an i7 CPU and which mobo to use. I'm looking at moving to an ATI HD5850 or 5870 as a GFX card depending on what I spend on the mobo, cpu and RAM.
My current specs are:
Mobo: ASUS RoG Commando
CPU: Intel Core 2 Duo EE600 @ 2.4GHz
RAM: 2GB
GFX Card: ASUS Geforece 8800 GTS
I already have a beefy power supply (Enermax 1000watt) and storage isn't an issue.
My budget is R8K - R10k. In a push I could probably go to R12k but only if it's going to be worth it. I'd prefer to stick to Intel so either i5 or i7.
Thanks in advance.
RAM: 2GB
Thanks in advance.
