needing help with z10
michellej
Brackenfell, cape town
Hi,
This might be a silly question
I go on the Gumtree website to post a ad and I can't get the button to respond that allows me to select posting a picture I hold my finger on the select image and nothing happens.
Can someone please advise
Have you tried using the Tab key to get to select the picture, then press the Enter key?
Just remember a lot of these web sites are not 100% compatible with mobile OSes, they were actually made for desktop/notebook computers.
It always used to work with my note 2 and s3, the select button on Gumtree is solid green and it doesn't matter how many times I press nothing happens. It should take me to my gallery to choose
your problem is you think you are too smart.
if you can't provide helpful advice then just keep quiet.
:D :D
Dammit, I spilled some coffee while laughing like a madman!!
Thanks BB for the laufs.
Now be a good girl and behave.
