Neoconnect lite device with external Directional Antenna
Has anyone done a speedtest with a neo lite device connected with a external Directional Antenna
Nope - no external directional antenna, but I get pretty much what Neotel have said I would. Would be interesting to see if anyone gets better results on the Lite Device and specifically with an external directional antenna.
http://www.speedtest.net/result/364593195.png
this is really weird but on my laptop i get around 15 to 17 Kb/s and on my Desktop computer i easily get 17 or more, sometimes 19Kb/s for hours and hours on end
well i have a diractional Antenna on my roof witch i use with my t-mobile data card on the vodacom network, all i need to get is just a pigtail then i will be able to hook it up to my neoconnect lite device and do the test.
A little off the topic. I hope neotel can upgrade there neoconnect lite network speed from 156kbps to something to 384kbps then lite will be worth it
because at the moment downloading 700mb ETA 24hours just to long
Is that what they plan to do?
They already did it, its called the Neotel PRIME ... @ 1500kbps
Yip. Lets hope for that Christmas present then. If you still believe in the fat man in the red jump suit...
