NeoGo and a USB Wireless Router
Fuzz_Master
Hi All,
I have been looking through the forums to find some help and there are no specifics that I have come across for my problem. Any help or direction to previous answers would be most appreciated.
I recently purchased a wireless router locally that has two usb ports for sharing 3G connections. There is no support in the setup for SA and therefore you need to enter the settings manually. This is where I am stuck.
Further details:
Windows 7
Router is visible and can connect and share files with another computer wirelessly
Router is Sitecom
NeoGo data card
I need to know if anyone has this router (as I said available locally) and has got it to work with NeoGo, or all the generic Neotel settings (connection method (PPP, PPTP, L2TP?) and all the associated settings (MTU, gateways, etc).
