Neotel Prime device call lock
cryptic1
Esplanade, Durban
Hi guys :)
Regrettably the people @ home are abusing my service in so far as using the free 120min within a matter of a day or two :(. I'm aware of the long press * to keylock the device but is there any other way to bar calls being made on this device?
I wanted to call the customer centre but I would prefer that the guilty parties @ home not over hear the conversation :o
Please help, thank you in advance :)
Yes there is, but this is a bit drastic. Go to settings, then security. The PIN is 0000. Then look around in there. There is an option there to block all outgoing calls. Bottom one if I remember correctly...
Unfortunately, you'll have to go back into the security settings and take off the outgoing block to make a call, then put it back on again. Takes like 20seconds, but it means that whoever is abusing your phone won't know how to use it anymore :D
Hope it helps
Hope it helps
Thank you mate :), really appreciate it.
