Hi guys
Not sure if this is a hardware or software problem so I posted it here, I bought 6 of these network cards, installed 3 successfully but I can't get the others to install...
I downloaded the latest software for the network cards but still the following happens:
The instructions indicated that I had to install the software before installing the hardware on the motherboard.
So I installed the software which prompted me to shut down the PC and then removed the power cord and the insert the network card in the PCI slot.
I get the following error after restarting: Code 10: Network card can start, or something like that!
Any help?
Any help?
